I'm not sure exactly what you are trying to achieve, but I can't think of any reason you wouldn't be able to do it on FG. We create multi-level frames all the time, using FG, and treat each "section" as a sub assembly for detailing purposes. I do this by creating each section of the frame as a standal,one in FG, and then assembling them in a top level frame assembly model.... using standard contraints. That way each piece is it's own assembly for detailing. I do not detail each piece of the frame separately, but since each is a unique part... you could do that easily enough.
As far as re-using frames... if you mean that you want to copy them... you can do that with Vault copy design.... and possibly design assistant (I don't use that so I can't say for sure).
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
One way I have done this is by not creating subassemblies, but creating view representations for each "weldment" that needs to be detailed in a drawing. When detailing the weldment, set the view to be associative to that representation. I also make sure to lock the view representation so no added parts appear when added afterwards. We dont use much of the bom side so I am not sure how this will affect that. drawingwise it has worked out. I have tried the derived part option and doesnt work out well. Parts dont update and if structural steel changes they dont update in the derived part. So far this has been the best option for us.
You tube is a good place to start in my opinion! Rob Cohee (Autodesk Guru now doing PLM unfortunately) did a few videos about fundamentals of inventor. He did 2 on frame gen. I follow his way of doing it and we use frame gen quite a bit and I have never had any issues (other than some bits of it are limited, but that's another story). http://www.youtube.com/watch?v=KGuUrMigdmI http://www.youtube.com/watch?v=Z1LaPODFXSo if these links don't work Google rob cohee frame generator and it will be there.
Thanks guys.
Been a bit busy over the past week, I will let you know my experiences using FG a little later. My findings so far...The first thing that I found that is that I created a large frame, then demoted parts to Sub assemblies. This worked well untill I had to remove and replace frame members. This broke the frame, as I had to promote and then demote again, causing the subassembly to loose contraints.
I will do it differently next time to create more stable assemblies which can be managed a little eaisier. The sub assemblies maintain the FG link, which is great, but deleting/replacing etc caused issues.
I will try ChrisB's solution of individual "sub Frames"
I am currently detailing using design view reps, and the BOM is an absolute disaster, It will have to be excel tables, until I can work out what to do at a lter stage. No time to learn, the deadlines are here....
Maybe this link is helpfull for your BOM problems? It is a bit of a routine but it works..
http://inventortrenches.blogspot.nl/2011/03/understanding-autodesk-inventor-frame.html
