Is anyone else having the following problem:
The only workaround for this that I've found is deleting the frame member with frame generator, editing the wireframe, then regenerating the member and the trims. This is counterproductive!
I've included "before/after" pics to illustrate:
We have had a report of something similar to your discription and it is being addressed. I have no time frame at this time to give you of when it will be addressed.
Has this issue been resolved? I am having a similar issue with beams rotating for no apparent reason. My frame in planar and I have tried deleting an replacing members, grounding my sketch, constraining the planes and nothing works. Curiously when you zoom into the effected areas and measure, Inventor tells me the dstances are 0.0".
Jason
