Inventor Forum
Frame Generator (2015) - Members rotating on Update
2 REPLIES 2
292 Views, 2 Replies
Is anyone else having the following problem:
  1. I've created a frame with members running vertically, horizontally and at various angles.
  2. Angled members are trimmed at the face of horizontal/vertical members where they intersect.
  3. I need to change the position of an angled member, so I edit the dimension of the wireframe sketch.
  4. I finish sketch & return to the frame, and the angled member is now rotated around the wireframe line at a random degree.
The only workaround for this that I've found is deleting the frame member with frame generator, editing the wireframe, then regenerating the member and the trims.  This is counterproductive!
I've included "before/after" pics to illustrate:
2 REPLIES 2
mercerc
We have had  a report of something similar to your discription and it is being addressed. I have no time frame at this time to give you of  when it will be addressed.
Charlie M
Inventor Product Support Specialist
ball
in reply to: mercerc
Has this issue been resolved? I am having a similar issue with beams rotating for no apparent reason. My frame in planar and I have tried deleting an replacing members, grounding my sketch, constraining the planes and nothing works. Curiously when you zoom into the effected areas and measure, Inventor tells me the dstances are 0.0".
Jason
