Inventor General Discussion
ghmail16
Message 1 of 9 (354 Views)
Frame Copy
354 Views, 8 Replies
10-18-2012 06:14 AM
I have made a Door with Frame Generator and I want to make an other one like this with higher height. So I copied and
pasted the files of Frame with windows explorer and then changed the Frame Height of the new file assembly. But that changed the height of the first door also. I guess because the new door is still related with the old frame. What can I do to copy frame objects that I want to change partially
Hi ghmail16,
Depending on the version of Inventor are you using, you might be able to use the iLogic Design Copy tool. It was included in the 2012 and 2013 versions. It will copy and update the internal links of the frame. Note that you don't need to have used iLogic to use the iLogic Design Copy tool.
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/3364-Show_Me_3364/3365-Show_Me_3365/3747-iLogic3747/3748-iLogic_D3748
The Copy Design tool in the SDK will work as well.
Paul covers both of these tool here:
http://cadsetterout.com/inventor-tutorials/the-secrets-of-copying-assembly-files/
I hope this helps.
Curtis
Distinguished Contributor
richiesuk
Message 2 of 9 (342 Views)
Re: Frame Copy
10-18-2012 07:22 AM in reply to: ghmail16
use copy design
Curtis_Waguespack
Message 3 of 9 (340 Views)
Re: Frame Copy
10-18-2012 07:35 AM in reply to: ghmail16
Hi ghmail16,
http://wikihelp.autodesk.com/Inventor/enu/2013/Help/3364-Show_Me_3364/3365-Show_Me_3365/3747-iLogic3...
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
ghmail16
Message 4 of 9 (278 Views)
Re: Frame Copy
12-17-2012 10:53 PM in reply to: Curtis_Waguespack
I used
Tools>iLogic>iLogic design copy
but with Inventor open and all files closed.
Thanks for the help.
Valued Contributor
JorisSteurs1246
Message 5 of 9 (177 Views)
Re: Frame Copy
04-26-2013 08:57 AM in reply to: Curtis_Waguespack
Hi Curtis
When I would do this workflow, i get a message that the skeleton could not be copied and that the origingal skeleton wil be used. This is not good because your original frame will be messed up when making changes at the new frame.
Is there a work around for this?
Joris
cbenner
Message 6 of 9 (172 Views)
Re: Frame Copy
04-26-2013 10:11 AM in reply to: JorisSteurs1246
For frames and tube & pipe assemblies, I've always had good luck with Vault copy design.  But... you have to be using Vault.  :smileytongue:
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
Valued Contributor
JorisSteurs1246
Message 7 of 9 (167 Views)
Re: Frame Copy
04-26-2013 11:38 AM in reply to: cbenner
Yep, Stand alone user, tried Vault many years ago but it slowed me down,
didn't allow me to go picking parts in old folders and some
other annoyances, so I didn't use it anymore since.
Joris Steurs
Design & Fabrication
www.distep.ee
cbenner
Message 8 of 9 (164 Views)
Re: Frame Copy
04-26-2013 12:01 PM in reply to: JorisSteurs1246
I agree Vault has it's share af annoyances, but I'd be lost without it.
Have you tried Design Assistant?  I've never used it with FG, so I don't know how it handles the skeletons.
ChrisB
Valued Contributor
JorisSteurs1246
Message 9 of 9 (160 Views)
Re: Frame Copy
04-26-2013 12:10 PM in reply to: cbenner
Yes DA gives the same complaint as the ilogic copy design tool.
Joris Steurs
www.distep.ee
