Inventor Forum
Frame analysis
4 REPLIES 4
343 Views, 4 Replies
Frame analysis
Hi everyone.
Does Frame Analysis uses the finite element method?
If it does, does someone knows how to view/edit the mesh?
Thank you.
Kind regards.
4 REPLIES 4
blair
No it does not use meshing, this is the reason it's able to analyze large assemblies. It's only uses the physical properties to run the analysis.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
in reply to: blair
Indeed. I used Frame Analysis to work on a greenhouse because Frame
Analysis just wouldn't work.
Thank you for your answer.
Kind regards,
Bruna Silva
JDMather
I don't understand that statement.
Did you really mean, " I used Frame Analysis to work on a greenhouse because FEA Analysis just wouldn't work."?
blair
If the structure was produced using normal Inventor assembly of creating IPT's and assembled using constraints then the model must be analyzed using normal FEA means.
The only time you can use the Frame Analysis is if the structure you wish to have analyzed was constructed using the Frame-Generator module.
Delta Tau Chi ΔΤΧ
