Inventor Forum
Frame Analysis Node Release Example
1 REPLY 1
906 Views, 1 Reply
Could someone please explain the circumstances where 'Release' is applied to a beam (node?) when using the Frame Analysis tool.
MES
1 REPLY 1
henderh
Hi Mark,
  If the frame is to be analyzed as a truss (i.e. members are pinned together instead of being regarded as fixed to each other) you can add releases to the rotational DOFs specifying 'uplift - none'.
  The members with the uplift none rotational releases will be analyzed as two-force members, where they cannot hold a moment load (unless you apply gravity, then there will be bending moment loads within the beam).
 I hope this helps...
Thanks, -Hugh
Hugh Henderson
QA Engineer (Fusion Simulation)
