I believe there is a bug here.
When I changed to 4 and press Add parameter, sometime I got 1.0000 instead
of the actual number
Secondly, I had to change to user parameter and switch back to Model
parameter to see the value in the parameter box changed to 4 decimal places
Chris
"Bryan Kelley (Autodesk)" wrote in message
news:5179667@discussion.autodesk.com...
Hello Chris,
Within the text dialog, change the X.XX number from 2 to 4 and press the
Add Parameter button (d0 icon) to the right. In the attached example I set
it to 5 places after the decimal. I hope that helps.
Thank you,
Bryan
bryan.kelley@autodesk.com
Technical Liaison - Rapid Response Team
Autodesk Inventor®
Manufacturing Solutions Division
Autodesk, Inc.
7995 SW Mohawk
SouthCenter, Bldg A
Tualatin, OR 97062
Tel: (503) 692-8335
Fax: (503) 692-1630
"Ch
ris (IV11 Pro. SPxx)" wrote in message
news:5179662@discussion.autodesk.com...
Please see the attached image - How to change the parameter to 4 decimal
places?
Thx
IV11 Pro. spxx
Window XP Pro sp2
Pentium 3.2 Ghz, 3.0 GB of RAM
NVIDIA FX 3400 8.1.7.2
