Has anyone been using the foreshortened dimensions in version 2015.
Is it possible to dimension from a line to a thru hole?
It is possible to dimension to a line and then drag to a circle after you have first created a foreshortened dimension, but if you select a line and a circle there is not a dimension type option on the right pick menu.
Joel Schmechel
Autodesk Inventor Professional 2015, Build 159
Windows 7 Professional SP1
HP Z820 Workstation
Intel Xeon CPU E5-2643 v2 @3.50GHz 3.50 GHz
64 GB of Ram
GeForce GTX 780Ti
