When I click the Force command in the LOADS panel when doing a Frame Analysis, I don't get a dialog box. All I get is a select origin box with an arrow. There is no way to change the Magnitude value or the Angle of Plane as per instructions in the tutorial. I have tried numerous ways to get a dialog box to appear, but I can't find out how. Can someone tell me why I am not getting a Dialog box? Thanks!
What is the exact url of the step where you are having difficulty?
Did at any point the tutorial tell you to Right Mouse Button>More Options?
or
did at any point the tutorial tel you to go into the Frame Analysis Settings and uncheck the Use HUD in Application on the General tab?
