Inventor Forum
Folding in sheet metal
4 REPLIES 4
safwan
1093 Views, 4 Replies
Hello guys,
I am facing aproblem regarding folding in sheet metal. Below I attach the drawing (.ipt) file. Initially I have 1.5 mm in thickness, and I can do folding perfectly. But when I change the thickness to 2 mm, the folding went wrongly. You can refer to the image that I attached.
Then what I do is I delete all the fold, change the thickness to 2 mm, and redo the fold, but it still went wrong.
Any pro guys please help me, and thank you for your help.
4 REPLIES 4
ped20
in reply to: safwan
If i am not wrong, the Hole & small gap resisting for Fold to happen. better you do those holes& that cut after fold creation.
Kiran
Did you find this reply helpful ? If so, use the Mark Solutions! Accept as Solution or Give Kudos!Kudos - Thank you!
safwan
in reply to: ped20
Thanks for replying. I understand that the small gap could be culprit. After I follow your instruction, how to do the folding of the cut area tu go down 90 degrees?
JDMather
in reply to: safwan
Wouldn't it be a lot easier (no calculations) to model in the finished form rather than folding a flat sheet?
Aren't the finished dimensions the controlling dimensions?
The CADWhisperer YouTube Channel
chad38
in reply to: safwan
I'm not sure why you don't model this as a finished, bent part, then make a flat?? Even if all the customer has is a flat to give you, you'd be better off figuring out the formed dims one time because if the part gets revised, much easier to make the modifications.
HP Z420 Workstation
Intel Xeon CPU E5-1603 0 @ 2.80 GHz 2.80 GHz
12.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Solid Edge ST9 MP1
Inventor Professional 2015
Autocad 2015
SolidWorks 2015
