I'm looking for a way to reference a folder name that contains my part / assembly. I want to use that folder name in the title block of my drawing.
For Example:
.workspace\I want this folder name\not this folder\or this folder\part.ipt
OR
.workspace\I want this folder name\not this folder\or this folder\assembly.iam
I've searched around for awhile now, but I can't find a solution.
Thanks for your help,
-Ryan
Solved by Cadmanto. Go to Solution.
Welcome to the forum.
Take a look at this thread and see if it helps you.
http://forums.autodesk.com/t5/Inventor-General/show-the-file-path-in-title-bar/td-p/3943755#M472463
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thanks Cadmanto. Unfortunately that's not what I'm looking for.
I am only looking to 'capture' our customer's folder name of the Inventor part/assembly's full file path. Then 'pass' the folders name into my drawing to be used in the title block.
Our company's network structure is like this:
server\drawings\customer 1\machineA\replacement part01.ipt
server\drawings\customer 2
I'm hoping to automate the insertion of our customer's name based on what folder the part file or assembly file is stored.
I think then the only way you are going to accomplish this is through iLogic.
I am not very prolific with iLogic so that is not something I can help you with.
You might want to consider posting this in the customization forum to see if anyone there has a routine that can help you with this.
I think iLogic is going to be the way to go. If I could somehow isolate a certain part of file path string and set it to the 'Company' iProperty, then everything would work.
