Inventor Forum
fold/unfold a cone shape
13 REPLIES 13
Message 1 of 14
kdale2006
2938 Views, 13 Replies
I need to add some geomerty to this part in the flat position.
This is a circuit surface and the only circuit layout available is in the flat pattern.
IV2010 has the fold/unfold options which should allow me to place the circuit layout onto the unfolded part.
If I unfold this part and then refold it, it does not refold correctly.
I thought that it might be because it does not have a flat section in the bend but even adding a flat section does not help.
Am I doing something so far out of the sheet metal range that it's not possible?
Any help, advise or otherwise would be appreciated.
thanks
Ken
13 REPLIES 13
Message 2 of 14
in reply to: kdale2006
It appears to work correctly in both Folded and Flat Pattern
modes here. What error are you seeing?
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3,
AIP 2009-SP1 PcCillin AV
AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT 512MB
XP Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
Message 3 of 14
kdale2006
If I just use the "Folded Model" and the "Flat Pattern" from the browser tree, it does work fine.
I need to add circuit traces to the flat pattern. IV2010 has a new feature "Unfold and Refold" that will let you add features to the unfolded part that will remain when refolded. When I use the "Unfold" command and then "Refold", the part does not go back to the orginal folded configuration. Even if I just "Unfold" and "Refold" without any alterations, it does not go back to the original form. I maybe asking for something that is not possible with a cone shape. I'm hoping that it is something I am doing wrong or need to approach it from another direction.
Ken
Message 4 of 14
Have you gone through the 8 steps in this portion of New
Features Workshop under Help?
Expert
Expert.
AIP 2008 SP3,
Message 5 of 14
kdale2006
Yes, I did go though that.
If I pick the end of the curve as my fixed surface and then pick the cone or curve as the bend, it unfolds or flattens as it should. If I pick the end and surface to unfold, it does not fold all the way back.
I thought maybe because I did not have a continued surface that was flat that could be the issue so I added a small flat surface from the end of the cone. The results were the same, it does not refold back the orginal shape.
Ken
Message 6 of 14
If I add a feature in the flat, this is what I
get.
Expert
Expert.
AIP 2008 SP3,
Message 7 of 14
If I do a unfold/refold, the result is the same.
Expert
Expert.
AIP 2008 SP3,
Message 8 of 14
kdale2006
What you you are showing is what I am getting too. The refold does not close the cone or loop back up.
It has a large gap instead of the small gap as in the original before the unfold.
Am I missing something or am I asking for something that the software cannot do?
Ken
Message 9 of 14
Not sure. I'll defer to Seth H. on this one.
Expert
Expert.
AIP 2008 SP3,
Message 10 of 14
kdale2006
Thanks for looking at it.
Hopfully Seth will see this and comment.
Ken
Message 11 of 14
There's definitely something amiss here; folks are
digging in and will post up soon with the results of their
investigation.
Seth
I
need to add some geomerty to this part in the flat position. This is a circuit
surface and the only circuit layout available is in the flat pattern. IV2010
onto the unfolded part. If I unfold this part and then refold it, it does not
refold correctly. I thought that it might be because it does not have a flat
section in the bend but even adding a flat section does not help. Am I doing
something so far out of the sheet metal range that it's not possible? Any
help, advise or otherwise would be appreciated. thanks Ken
Message 12 of 14
kdale2006
Thank you
Message 13 of 14
saketsatta
Hi Ken,
The issue you described has been logged as #1200183 in our database but I am not sure when a fix will become available.
This "clipping" effect after refold happens for cones with an angle > 180 degrees. So depending on your requirements, a possible workaround for refold of large angle cones could involve unfolding, modifying and refolding smaller angle cones separately. You could then join them afterwards (using mirror solid, perhaps).
Saket Satta
Inventor Development
Message 14 of 14
sumit_waghmare
I think I've found the solution.
when you revolve the surface of the cone, don't revolve 'FULL', revolve 359.5º
This will resolve the issue.. tell me it works or not! it worked on my machine, when i face similar problem
Autodesk can help
