Inventor Forum
foggy view in assembly
7 REPLIES 7
Message 1 of 8
NachitoMax
848 Views, 7 Replies
Hi
my Inventor has recently started to look foggy in assemblies but its not all the time. its kind of frustrating..... any ideas? a few images attached both take from almost the same view (with a slight movement which removes the fog).
ive been through my settings but i cannot find anything.
i have a good new machine with 8gb ram, a 2ghz processor, 2gb dedicated graphics using windows 7 64 bit.
it doesnt do it in part view
Nigel
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
7 REPLIES 7
Message 2 of 8
LT.Rusty
in reply to: NachitoMax
Looks to me like something to do with your lighting.  Which shadows / reflections do you have enabled?  What material are you using there?
Try disabling all your shadows EXCEPT for ambient shadows - leave those on.
Rusty
Message 3 of 8
Cadmanto
Nigel,
Is this the only assembly you are seeing this condition with?
Can you reproduce this on a different machine?
Are your graphics drivers up to date?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 8
NachitoMax
Hi
Yes it is only in the assembly environment. I cannot re-create it on another computer even one that has much less spec than mine. My graphic drivers are up to date and its a brand new strong machine.
I'd like to think it has something to do with my lighting in the assembly environment. i do not however, know how to change my lighting setting in the asembly environment..... i had an issue a while ago where i had a medium wood texture on a unit but i couldnt see it due to brightness. If you could give me a pointer, it might fix 2 problems at once lol.
Nigel
Nacho
Message 5 of 8
rdyson
Here's my (out of the box) lighting.
PDSU 2016
Message 6 of 8
NachitoMax
here is mine. my settings are exactly the same as yours. Im not sure whats wrong then. Notice the fog in background. its really frustrating as there are times when i can barely see for the mist.
Thanks 🙂
Nigel
Nacho
Message 7 of 8
Hochenauer
in reply to: rdyson
Have you checked your document settings? There is a depth dimming option there.
Just a guess...when I turn that on, far edges become dimmer.
Gerald
Gerald Hochenauer
Senior Principal Engineer, Inventor
Autodesk, Inc.
Message 8 of 8
NachitoMax
in reply to: Hochenauer
Hi
yes that was it Smiley Very Happy
it was turned off in my document settings and turned on in application settings which is why it happened on every file
Thanks man 🙂
Nigel
Nacho
