Hi, I am fairly new to AutCAD Inventor. I am trying to get a turbine which is connected to a fly wheel to rotate. I am able to get the fly wheel to move correctly, but I am unsure how to connect the axle and the turbine blades. I have tried to attach it using a rigid joint, but it is obviously a bit more complicated than that. Any suggestions?
I have attached a picture. Apologise if it is unclear.
Solved by JDMather. Go to Solution.
What version of "AutoCAD Inventor" are you using (I assume 2010)?
Can you attach your assembly here?
Do you have a Mate-Flush contraints between the part origin planes.
Do you have an Angle constraint and using Drive Constraint?
