Inventor Forum
Flow Design Environment
3 REPLIES 3
626 Views, 3 Replies
Evening,
Just downloaded Inventor + Design Flow. I can open up both independently.
However there should be a Flow design option under the Environments tab on Inventor so I can see the streamlining of projects being worked on. I was hoping someone out there can suggest what I need to do to access Flow Design in Inventor.
What I see:
What the YouTube tutorial shows:
Many thanks
Ben
3 REPLIES 3
JDMather
Try placing your ipt in an iam and then access the Environments while in an assembly.
in reply to: JDMather
No luck, when I open the .iam in Flow Design it just loads a 3D sphere (not the shape I created), and in assembly there is still no Flow Design option under the Environments tab
Uninstall Flow design then reinstall, I had the same problem
