I also only show constraints of those entities I am actually having
issues with. As regards who is in control ..... you only think you have
control, your command authority is limited to issuing, there is no
assurance of compliance.
Bob Johnson wrote:
> When checking constraints in the Sketch mode, selecting Show All
> Constraints, the constraint list bars are displayed, stacked on top of each
> other, but I don't want then stacked, so I can not view all of the
> constraints. So, I move then, until they are aligned with the proper
> constrained points. When I select Hide All Constraints and then I again
> select Show All Constraints, there all stacked again. At the same time, the
> constraints have floated all over the place. Are these constraints
> undisciplined and questioning my command authority? Is there a procedure to
> stop these undisciplined constraints from stacking and floating? Thanks, Bob
Hal Gwin
Mechanical Designer
Xenogen
R9 Pro SP2
XP Pro SP2
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.6176 w/registry update
Dell UltraSharp 19" LCD
