Inventor Forum
Flip Normal in Assembly
13 REPLIES 13
Message 1 of 14
Talayoe
4271 Views, 13 Replies
Yo!
Just curious why, when I create a plane, I cannot 'flip normal'? There is nothing in the RMB click for it...and I am not sure why. Still there in part...just not assembly. Was it ever?
Alternatively, when I create a plane, is there a way to create with the normal in a direction of my choosing? Never tried to figure this one out cause I always had flip normal...
tks!!
-Randy
Inventor 2017 PDS
13 REPLIES 13
Message 2 of 14
innovatenate
in reply to: Talayoe
I checked in Inventor 2010, and the Flip Normal feature appears to function uniformly with the behavoir in Inventor 2013. You'll note there are also constraints in the model browser under plane work features in assemblies and there are none in parts.
Can I ask what you are accomplishing with the Flip Normal command? Maybe there is a different path to arrive at the same destination.....
Nathan Chandler
Principal Specialist
Message 3 of 14
Talayoe
in reply to: innovatenate
Honestly, its been 10 days and I have forgotten what project I was working on while having this issue.
I did resolve it, as I recall, but not with flip normal, just by creating the plane in a different makeup and getting my 'normal' to be the correct way from the start.
Thanks for the response tho, sorry I dont recall what it was. 😞
-Randy
Inventor 2017 PDS
Message 4 of 14
swthompson
Nathan,
I am having this same issue.  I have created a sub-assembly in which one of my parts was flipped ipside down.  I resolved this by changing to a flush constraint.
Now as I place the sub-assembly in a new assembly the same part flips upside down again.  I cannot figure out how to resolve it because the flush constraint solution does not work.  Others have advised to flip normal by pointing/right-clicking the work plane.  But, I do not find the flip option at all.
SWT
Message 5 of 14
JDMather
in reply to: swthompson
This sounds like a constraint selection issue.
Try changing Mate/Mate-Flush.
Can you attach the assembly here?
There might be a better workflow.
I don't recall ever using an assembly workplane for anything other than mirror of components.
The CADWhisperer YouTube Channel
Message 6 of 14
swthompson
in reply to: JDMather
I am trying to learn how to use Inventor so I could be way out in the weeds with what I am doing.  I attached the assembly.
Message 7 of 14
JDMather
@swthompson wrote:
I am trying to learn how to use Inventor ....
An Inventor assembly file *.iam is little more than a list of hyperlinks to the part *.ipt files and a record of assembly constraints.
Just look at the file size of the *.iam file you attached.
An assembly file is useless without the part files.  Attach the entire assembly (this includes the parts of the assembly).
(or at least the parts the exhibit the behavior that prompted this question)
Message 8 of 14
swthompson
Good.  I am reluctant anyway to post design details on a public site.  Can I send them to a private account?
Message 9 of 14
innovatenate
Are there any issues in assembly file? Running the Design Doctor should help resolve conflicts in the assembly. Is the part that is "flip-flopping" a natively created Inventor file?
I'll send an e-mail to get the files from you.
Nathan Chandler
Message 10 of 14
swthompson
Where is the Design Doctor?
Message 11 of 14
Talayoe
Hey,
On the title bar, the plus. If it is needed it will be RED otherwise it will be greyed out.
-Randy
Inventor 2017 PDS
Message 12 of 14
bbonner
Did someone actually answer this question?
Message 13 of 14
JDMather
in reply to: bbonner
No.  Well I guess Nathan did verify that there was no difference in behavior between 2010 and 2013 - no Flip Normal of assembly level workplanes.
Message 14 of 14
SBix26
Nathan answered the question indirectly.  I think the reason that Flip Normal is not available in assemblies is that assembly workplanes are not the same species as part workplanes.  An assembly workplane is essentially a component, and is constrained in the same way as other components.  If a component is mis-oriented (flipped the wrong way), you adjust your constraints to get it turned the right way.  Same with a workplane.  Check its constraints and change them to constrain it the opposite direction.
Sam B
Inventor Professional 2015 SP1 Update 3
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
