Chun,
Keep including more screen shots of Inventor 11, so we can see all the new
features. 🙂
Stan McLean
"Chun Du (Autodesk)" wrote in message
news:4858981@discussion.autodesk.com...
Josh,
Not sure if I understood your question correctly. For what I see from the
picture, you can make a workplane above the surface where you want the
countersink/counterbore depth, then sketch a point on this workplane and
make countersink/counterbore hole from there. Attached is a screenshot for
what I described. Hope this helps!
Chun Du
Autodesk, Inc.
wrote in message news:4858936@discussion.autodesk.com...
Is there a way to "flip" a countersunk hole so th
e hole starts at a plane,
extrudes a specified distance then goes to the countersink diameter for the
rest of the part depth? I've attached a picture to help demonstrate what
I'm saying.
I've ran into this situation a fair bit, and first I tried using a regular
countersink hole with the countersink diameter smaller than the hole
diameter (i.e. hole becomes countersink and vise versus), but got an error
message 😞
