I am working on a hinged door assembly that consists of a frame sub-assembly, and 2 door panel sub-assemblies that each have 4 hinged sub-assemblies that I have made flexible. I am trying to figure out how to constrain these doors so that they "operate" correctly and not spin 360 degrees when I manipulate them in the overall assembly.
Thanks for the help,
Anderson
Solved by anderson51. Go to Solution.
Solved by Curtis_Waguespack. Go to Solution.
Hi anderson51,
If you create a constraint limit in the subassembly, and then make the subassembly instances flexible at the top level assembly, I think you should get it to work:
I hope this helps.
Curtis
Can you zip up and post your door and hinge assembly and parts? What version of Inventor are you using?
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
I couldn't attached the entire assembly as it was too large of a file, but i did attached the parts in question.
Thanks for the help.
Hi anderson51,
I just tested this using your files and it works as expected. Unfortunatly I can't post the files back due to the Inventor version I'm running at the moment, but here is a screen shot showing the selections and inputs for the angle constraint with limits on the hinge:
I hope this helps.
Curtis
