I'm looking for some advise on flexible assemblies.
My model includes 4 identical hydraulic ram sub assemblies in a main assembly.
I want to be able to move each of these rams independant of one another inside the main assembly.
Can this be done?
I don't want to have to model each ram as individual parts in the main assembly.
Cheers
Can this be done?
Yes.
Right click on your sub-assemblies and set them to Flexible.
Attach your assembly here.
I've set both of the rams to flexible on the RHS of the assembly but when trying to move the clamp arm down it refuses to move.
I've attached the assembly. Hopefully it works. (The model is still ongoing at the moment so it is a bit of a mess).
An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
Give the size of your iam file you will probably have to share through Autodesk360 link.
Save As Pack and Go to a single folder first. (skip the extraneous stuff)
I don't know if this is because you didn't include the parts - but the browser does not show the subs set as Flexible.
Thanks Mark.
Your post made me go and check the ram assembly. I had forgotten to remove the contraint on the ram which had stopped the piston moving in and out.
Works perfect now.
Cheers!
