Larry,
When it happens next time, could you send me the files?
Thanks!
Johnson Shiue
Inventor QA Tech Lead, Autodesk
johnson.shiue@autodesk.com
wrote in message news:5662421@discussion.autodesk.com...
I think I've found a reason as to why there is a lot of trouble with
flexible asm and the flying screws and such. I ran into the issue today, as
well as many, many other times. I turned flexible and bam screws all over
and nothing would move right. So I went in and flipped one of the asm over
and re-tried flexible.....everything works fine. The trick to this seems to
be, if you have similar asm or mutiple asm(s), they need to be facing the
same way. ie, if your planes are on the top in one instance, they must be
on the top in other instances as well...or you get wacky behavior. It must
have something to do the 'normal' direction of the planes, if they are
opposed....everything gets all screwy. Another time I have found issues is
with the constraints themselves....like you accidently picked the hole axis
instead of the hole axis. When in doubt delete the
contraints..reconstrain..making sure you picked the right pieces. More
often than not....the issuses go away. Anyone else notice similar things?
Thanks, Larry
