Inventor General Discussion
Member
Tank3d
Message 1 of 6 (374 Views)
Flattening a Cone with Knuckle
374 Views, 5 Replies
11-16-2012 09:15 AM
I need help figuring out how to get a flat pattern from a cone with knuckle.  I have attached a file so you can see what I am looking at.  Any help would be greatly appreciated.  I am using 2013.
JDMather
Message 2 of 6 (345 Views)
Re: Flattening a Cone with Knuckle
11-16-2012 01:10 PM in reply to: Tank3d
Contour Roll.pngI don't think Inventor Contour Roll can flatten that geometry properly.
I think the solver is limited to parts that would be rolled from a cylinder flat to a cylinder.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Member
Tank3d
Message 3 of 6 (294 Views)
11-19-2012 06:43 AM in reply to: JDMather
I tried using a loft and a revolve and then creating the contour roll for the top knuckle and straight flange but the pattern will flatten to get the cone cut out but not flatten the knuckle and straight flange.  Is there a differnet way of creating this model so it will flatten?  Do I need to create special tooling for it to recognize how the part is created?
JDMather
Message 4 of 6 (278 Views)
11-19-2012 08:01 AM in reply to: Tank3d
Inventor will not return proper flat pattern of this part.
You will need a  3rd party add-in.
Member
Tank3d
Message 5 of 6 (271 Views)
11-19-2012 08:16 AM in reply to: JDMather
do you know of any third party software to do this?
JDMather
Message 6 of 6 (266 Views)
11-19-2012 08:20 AM in reply to: Tank3d
autopol and several others have been mentioned here in the past.
I do not have any experience with any of them.
I think you can download a trial that will let you do a limited number of saves.
