Hello everyone :).
Does anyone know how to make flattened elipsoid in AI? I know some options using some other software but not using AI.
Thanks in advance.
Solved by JDMather. Go to Solution.
If you were simply after an easy solution (within reasonable manufacturing tolerance), check this simplified example.
Nice! Simplified solution is super, just tell me why value in loft condition of field weight exactly 4.300 ul ? How you get this value?
I had the sketches of the ellipses as a trial and error guide, the I erased them once I had the geometry almost identical.
