Inventor General Discussion
New Member
joe12345
Message 1 of 6 (277 Views)
Flatten A Curved Part
277 Views, 5 Replies
10-03-2013 11:24 AM
I tried following the advice in this thread  but to no avail. We need to fabricate a curved component but in order to do so we must first flatten it. Usually when I come across something like this I just do the math and draw it out by hand but I really need to learn how to have autodesk do it. Most of the literature I found was not very explicit. Any help would be greatly appreciated.
(I'd attach an example file but that 1.5 mb limit sort of removes that capability)
*Expert Elite*
JDMather
Message 2 of 6 (272 Views)
Re: Flatten A Curved Part
10-03-2013 11:26 AM in reply to: joe12345
Find the red End of Part marker in the browser.
(End of Folded on sheet metal parts EOF)
Drag the red EOP to the top of the browser hiding all features.
Save the file with the EOP in a rolled up state.
Right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
New Member
joe12345
Message 3 of 6 (261 Views)
10-03-2013 12:26 PM in reply to: joe12345
Well at least I learned a cool way to compress an ipt :smileyhappy:. Never realized that it would reduce the file size just by doing that. Sadly it's still 8 mb but that's small enough to upload to a cloud host (in this case fileswap).
*Expert Elite*
mcgyvr
Message 4 of 6 (249 Views)
10-03-2013 01:05 PM in reply to: joe12345
Now here is another tip.. Get a dropbox account so we don't have to wait for 30 minutes or create an account just to download that file.. I'm outta here in 15 minutes so I'm not able to help you today.. sorry.
With dropbox you can put stuff into the "public" folder then just right click on it and select "copy public link" then post that..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Distinguished Mentor
ccarreiras
Message 5 of 6 (223 Views)
10-03-2013 09:11 PM in reply to: joe12345
Hi!
 Isn't a typical part to produce bending with press brake or die formed.
This part as to be made with plastic deformation, it means that in some part of the process, the thickness will vary across the part, so the first rule needed for inventor flat it's violated. This part will never flat with inventor.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CarlosC
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
Valued Mentor
stevec781
Message 6 of 6 (201 Views)
10-04-2013 01:25 AM in reply to: joe12345
I havent looked at the part but I suspect the solution will be to export it to Rhino and use the smash command.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
