Inventor General Discussion
New Member
joe12345
Message 1 of 6 (274 Views)
Flatten A Curved Part
274 Views, 5 Replies
10-03-2013 11:24 AM
I tried following the advice in this thread  but to no avail. We need to fabricate a curved component but in order to do so we must first flatten it. Usually when I come across something like this I just do the math and draw it out by hand but I really need to learn how to have autodesk do it. Most of the literature I found was not very explicit. Any help would be greatly appreciated.
(I'd attach an example file but that 1.5 mb limit sort of removes that capability)
JDMather
Message 2 of 6 (269 Views)
Re: Flatten A Curved Part
10-03-2013 11:26 AM in reply to: joe12345
Find the red End of Part marker in the browser.
(End of Folded on sheet metal parts EOF)
Drag the red EOP to the top of the browser hiding all features.
Save the file with the EOP in a rolled up state.
Right click on the file name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
New Member
joe12345
Message 3 of 6 (258 Views)
10-03-2013 12:26 PM in reply to: joe12345
Well at least I learned a cool way to compress an ipt :smileyhappy:. Never realized that it would reduce the file size just by doing that. Sadly it's still 8 mb but that's small enough to upload to a cloud host (in this case fileswap).
mcgyvr
Message 4 of 6 (246 Views)
10-03-2013 01:05 PM in reply to: joe12345
Now here is another tip.. Get a dropbox account so we don't have to wait for 30 minutes or create an account just to download that file.. I'm outta here in 15 minutes so I'm not able to help you today.. sorry.
With dropbox you can put stuff into the "public" folder then just right click on it and select "copy public link" then post that..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Distinguished Mentor
ccarreiras
Message 5 of 6 (220 Views)
10-03-2013 09:11 PM in reply to: joe12345
Hi!
 Isn't a typical part to produce bending with press brake or die formed.
This part as to be made with plastic deformation, it means that in some part of the process, the thickness will vary across the part, so the first rule needed for inventor flat it's violated. This part will never flat with inventor.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CarlosC
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
Valued Mentor
stevec781
Message 6 of 6 (198 Views)
10-04-2013 01:25 AM in reply to: joe12345
I havent looked at the part but I suspect the solution will be to export it to Rhino and use the smash command.
