Hello
Is there a easy way to convert 111.jpg (solid) to something flat, so i could make the template, and then i could soft solder it.
Regards
majusmiles
Solved by JDMather. Go to Solution.
Hi , thank You for the answer. I tried your way yestarday , but with no luck.
222.jpg - that is my result for this problem, different solution
I was wonder if there is a way to project surface or object or somethink like this function.
Or mayby make somethink solid and yhen explode it.
Cut 8 of these and solder.
Thank You, i made this (222.jpg), a bit different way but idea is the same. I was just wander if there is nicer or bether way
