Inventor General Discussion
0 Kudos
Post 1 of 9
Flat Pattern With Multiple Rips
540 Views, 8 Replies
02-28-2012 08:44 AM
Is there a way to choose which flat pattern shows up on a  Sheet Metal part where there are multiple rips?
Ex) a tank shell that is in quarters
I would do as multi-body solid and then push out the individual parts for sheet metal.
The holes aren't technically correct (go to flat pattern and wireframe mode - notice double lines because the sides of the cuts are not perpendicular to the flat).
Unless you have a swivel head plasma, laser, water jet.... to cut these...
Acctually this modesl includes multiple solids, and we recommend that you convert the sheet metal to part, and make it as multiple solid body, that you should be able to see multiple solid bodies in browser. Now please push the multiple solid bodies or derive it to multiple part file which should contain one solid. So you could convert the generated part file to sheet metal and create flat pattern, even create drawing view for the sheet metal and flat pattern.
When the model is updated, the part file derived from model will be updated, and the drawing view should be associative too.
River
2,132 Kudos
Post 2 of 9
Re: Flat Pattern With Multiple Rips
02-28-2012 09:16 AM in reply to: Atlas_Inventor
Sheet metal does not support multi-body solids.
Sounds like you might want to do Derived Components instead.
Can you attach the file here?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
0 Kudos
Post 3 of 9
02-28-2012 09:23 AM in reply to: Atlas_Inventor
I have attached an example of a shell from the past, thanks.
2,132 Kudos
Post 4 of 9
02-28-2012 09:49 AM in reply to: Atlas_Inventor
0 Kudos
Post 5 of 9
02-28-2012 11:06 AM in reply to: JDMather
Thanks I will look into using that.
We edit the DXFs before sending them away so they are just square cuts on the sheets.
2,132 Kudos
Post 6 of 9
02-28-2012 11:27 AM in reply to: Atlas_Inventor
If you have trouble figuring out the solution - hollar back.
I think you will find it an excellent work-flow for your needs/
Employee
38 Kudos
Post 7 of 9
02-28-2012 09:42 PM in reply to: Atlas_Inventor
While looking into the attached model, there are several seperated solids in model. In this case, please pre-select the face in the solid which you would like to see the flat pattern, and create flat pattern, the result will be the one you want to see.
Hope it helpful for you!
River
River Cai
Inventor Quality Assurance Team
0 Kudos
Post 8 of 9
02-29-2012 06:51 AM in reply to: Yijiang.Cai
Thanks that one seems to work well, except you have to delete the flat pattern if you want any other views which isn't favorable if you're making .idw of them, unless I am missing something there?
Employee
38 Kudos
Post 9 of 9
03-01-2012 11:01 PM in reply to: Atlas_Inventor
River
River Cai
