Inventor Forum
Flat pattern on weldment drawing
6 REPLIES 6
meck
1080 Views, 6 Replies
I have a weldment which includes a sheet metal part called sPart. I want to show a detail of the flat pattern of sPart on the weldment drawing and still be able to balloon the flat as the part of the weldment. So I clicked to add base view and selected sPart from the Preparation dropdown list under the Model State tab of the Drawing View dialog box. The problem is I cannot find an option for using the parts flat pattern.
Is this feature not available or am I missing something?
Mike Eck
Master Drafter/ CAD Programmer
Using Inventor 2018
6 REPLIES 6
blair
in reply to: meck
I don't think you can get there from here, You would need to create a new base view selecting the individual sheet-metal part and then selecting the "Flat-Pattern". You might be able to get the Balloon to use the Sheet by selecting all views on the sheet.
Delta Tau Chi ΔΤΧ
karthur1
in reply to: meck
The weldment is an assembly.  The flat pattern representation is only available for sheet metal parts. Your sPart... it is a sheetmetal part, right???
When you open the sPart, is there a "Flat Pattern" node shown in the browser on the left? If it is, you could place a base view of the sPart on the weldment drawing and you should be able to select the flat patten view then.
Does that help at all?
Kirk A.
Windows 7 x64 -12 GB Ram
Intel i7-930 @ 3.60ghz
nVidia GTS 250 -1GB (Driver 301.42)
INV Pro R2013, SP1.1 (update1)
Vault Basic 2013, SP1
meck
in reply to: karthur1
That's what I was trying to do but the option for placing a flat pattern is not there.
sPart is a sheet metal part that is welded in the assembly.
Mike Eck
Using Inventor 2018
japike
in reply to: meck
The option for a flat pattern isn't available when making a view from a weldment. You have to make the view from your part file.
Peace,
Jeff
Inventor 2022
JDMather
in reply to: meck
Post screen shot if you can't figure it out, or better yet, the assembly and drawing.
I just tried it and it worked fine with my files.
blair
in reply to: meck
Sounds like the "Flat-Pattern" hasn't been created in the IPT part file.
Delta Tau Chi ΔΤΧ
