Inventor Forum
Flat pattern of shelled part
14 REPLIES 14
Message 1 of 15
770 Views, 14 Replies
Hello I have created a shelled part, and have been trying to get a flat pattern with no luck. Wat wud be the problem?? Thanks in advance.
14 REPLIES 14
Message 2 of 15
billco-mfg
You need radii in the corners to make a consistent wall thickness.
Message 3 of 15
billco-mfg
I'm not sure how you would use the corner feature once you do this. If the end result is as simple as this file, I'd use sheetmetal feature from the start.
Message 4 of 15
Wat command shud i use to do this, as i have tried using corner seam and a relief hole to no avail. Thanks in advance.
Message 5 of 15
JDMather
I noticed Sketch1 is not constrained or using the origin for symmetry. I would use only sheetmetal tools for this part. You might want to read this document
http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf
Message 6 of 15
JDMather
After you have finished that reading I might do the part something like this.
(pull down the End of Folded marker in the browser.)
Message 7 of 15
JDMather
Oops, maybe like this.
Message 8 of 15
Thank you for ur help, i will read through the document and hope to pick up alot. I have tried to open ur tray file however i get an error saying it is in the educational version format and the part is invisible.
Message 9 of 15
Try reading the document first, I am sure it says in there something
about moving the EOP down in the browser
Message 10 of 15
JDMather
It was done in edu version - so after you analyze how I did it delete the file.
To see the geometry pull down the red End of Folded marker in the browser feature history tree as I instructed earlier.
Message 11 of 15
moretti999
I am still on v11, but as I see all the files in the conversations have the newer data scheme, hence my disability to open the files.
Is there a possibility to get around it or am I shut off completely?
It would be nice to participate in discussions with direct access to the problem parts.
AM
AM
Message 12 of 15
moretti999
I meant inability...
AM
Message 13 of 15
JDMather
If in N. America (and certain other location) download free Inventor LT from http://labs.autodesk.com to see the files.
Message 14 of 15
moretti999
It's a good suggestion, but at 30kb/s 9hrs seem to be an eternity...
I tried to use the download manager, but it doesn't download so I tried more traditional method which has this snail pace speed. My company is on T1 (here in Portland, OR, USofA)
Thanks for the attempt to help.
AM
Message 15 of 15
Your reseller may have copies of IV2008LT
wrote in message news:5867236@discussion.autodesk.com...
