Inventor General Discussion
Distinguished Contributor
0 Kudos
Post 11 of 24
Re:
11-10-2003 12:16 AM in reply to: jmartzig
The flat pattern for a hemisphere is a circle. But to get the correct size needed u will need to speak to the experts. Spinning is a bit of a black art. Its a very old method of working metal, and requires lots of knowledge. You might find that they are unwilling to part with this knowledge, and would rather just have the model of the finished item and work it out for you.
Martin
*Gwin, Hal
Post 12 of 24
Re: Flat pattern of a sphere?
11-10-2003 12:33 AM in reply to: jmartzig
Use a drawn part. One company I worked for had to make extinguishers
that were a sphere. We made 2 drawn halves and welded together. Just
draw the shape and let someone like Hudson Tool or Zero Manufacturing
draw the part and worry about how much material is required.
jmartzig wrote:
> has anyone done this? i would expect the pattern to look like one of
> those world maps thats all laid out flat. -Joe
Hal Gwin
Mechanical Designer
Xenogen
W2K SP4
Dell Precision 650
Dual 2.66 GHz Xeon
1.5 GB DDR
Quadro4 900 XGL
nVidia 6.14.10.4472 w/registry update
Dell UltraSharp 19" LCD
Active Member
0 Kudos
Post 13 of 24
Re:
11-10-2003 12:41 AM in reply to: jmartzig
We've had to have several parts spun for us. To make the inventor model we simply use a revolve of a profile. We then send the metal spinning company drawings of what we would like. It is up to them to make the result.
We've never had to make a spere, but we have had to make several types of circular fan venturi this way. It isn't that difficult to get this done in Aluminum, but getting a precious metal to do it in a very small size is probably a different story.
Re:
11-10-2003 01:31 AM in reply to: jmartzig
"Duncan Anderson" wrote
in message news:7B7DFF51E6AEFED227E38E77328698E5@in.WebX.maYIadrTaRb...
> There madeby stretchng and compressing the material, like other pressed
shapes.
> Inv. Flat Pattern doesn't do distortion, only bends etc.
> Duncan
> ps. I'd like to see InvRx do a flat pattern of a Cortina MkIII bonnet.
The Cortina would be easy - Nice and boxy... :smileywink:
Rory
0 Kudos
Post 15 of 24
Re:
11-10-2003 01:36 AM in reply to: jmartzig
Maybe if they would stop using cheap material and go with GOLD (very ductile) the could make the part - LOL.
*Howard, Jeff
Post 16 of 24
11-10-2003 01:50 AM in reply to: jmartzig
See ivCF "Segmented hemisphere".
"jmartzig" wrote in message
news:f19b332.-1@WebX.maYIadrTaRb...
> has anyone done this? i would expect the pattern to look like one of those
0 Kudos
Post 17 of 24
Re:
11-10-2003 02:05 AM in reply to: jmartzig
"impressive luke" (jeff). that may just be the thing they are looking for. thanks. -Joe
*Autodesk\
Post 18 of 24
Re:
11-10-2003 02:34 AM in reply to: jmartzig
In general, this is a difficult problem to solve. The best solutions to this
problem seem to come from ball manufacturers. Baseballs only use two pieces
of leather, although the resulting seam is pretty complicated. The ends wrap
around, so it would either take multiple forming operations or some
interesting tooling.
I have seen tip shapers for pool cues that looks like a hemisphere with a
large lip.
http://store5.yimg.com/I/welovepool-inc_1766_5035054
You could probably get tooling to stamp a shape like that and then trim the
edge.
No matter how you make it, you would need tooling to hold the pieces while
they are being soldered. Even so, it would be difficult to get a good seam.
I worked my way through college as a silversmith, and I thought that shapes
like spheres, etc., were available through the wholesale jewelry supply
houses.
Loren Jahraus
Autodesk Inventor Workflow Team
news:f19b332.1@WebX.maYIadrTaRb...
> ha ha - no. i know it sounds pretty funny. but a customer of ours (a
jeweler) is looking for ways to make a piece of jewelery cheaper. a way to
do this (he thinks) would for us to be able to lay out a flat pattern of a
sphere, and have it welded about all seams. i thought i could do it in
halves, but that dog wasn't hunting either. i thought it may be
un-producible in inventor. i could probably get close using regular ol'
autocad, using a that flat pattern of the earth like i mentioned above. -Joe
*Professor, The
Post 19 of 24
Re:
11-10-2003 02:56 AM in reply to: jmartzig
Very Cool....!!
"Jeff Howard" wrote in message
news:A3813704443D7265CEC12505FED17B61@in.WebX.maYIadrTaRb...
those
*Harvey, Roger
Post 20 of 24
Re:
11-10-2003 06:53 AM in reply to: jmartzig
How big does this sphere have to be?
What is the material?
I have been involved in jewelry manufacturing for
over 25 years and can probably give you an idea of the available
approaches.
Roger
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
