I have a part that I drew in Inventor 2014 sheet metal view and it won't let me save it in a flat pattern. Why? That was kind of why my company wanted this version so that I could create flats and save them. Am I doing something wrong?
OK Nichole, put on your flame suit before reading, I try to avoid this, but -
are you serious? How can anyone possibly answer this question without the ipt file or at least a screen capture picture?
Q1. Did you use only sheet metal tools to create the part?
Q2. If you used other tools, how much experience do you have creating sheet metal parts in Inventor?
Q3. Have you saved a flat pattern before in earlier release? How?
Q4. Is your part made up of planar faces, cylindrical or conic faces or with the Sheet metal Loft tool?
Q5. I'm not sure what this means? "I drew in Inventor 2014 sheet metal view" Can you elaborate? When I think of views I'm thinking idw or dwg (2D).
Q6. Did your VAR demonstrate that the software would do what your company needs?
Q7. Did your VAR offer training?
Q8. A quick search indicates you have asked similar question before http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-Prof-2013-Saving-Flat-View/m-p/3661992 what is different now?
Man, I guess you told her what for huh?
People don't bother taking the blinders off sometimes... MOST everything anyone wants to know how to do in Inventor exists in the TUTORIAL secetion of their software, sad to say, from experience I've seen far too many people that don't even know the tutorials even exist
Q8. Was the key.
But again, a year later no response by OP to the questions.
your loss.
We cannot possibly know what the problem is without more details.
Good Luck in your pursuits.
Nicole,
I would like to understand this issue better. There are certainly limitations in Inventor sheet metal as are in any software package. I need some specifics in order to tell if you are seeing a limitation, a bug, or something else. Could you post the part here or send it to me directly (johnson.shiue@autodesk.com)?
Thanks!
