How do I make this flat pattern correct... it might be that I have to use a different way to folded up the crimp But I'm new to crimps
- Bear
Solved by JDMather. Go to Solution.
Inventor will not flatten that part.
JD is right, Inventor can't produce a correct flat of that part. There are third party software add-ins and stand-alone suites that can, however. This was produced using SPI Sheet Metal on your unmodified ipt:
I'm not sure they wanted a Rip in the part.
Looked like a draw formed part.
