Hey guys
I have made a sheet metal part based only on a contour flange (so far).
My sketch consists of two lines and a spline.
It works fine and I can make flat pattern and everything - Nothing is wrong.
I have now cut out a feature in the flat pattern (And yes, I know it states that it is added exclusively to the flat pattern)
I would like to know if there is a way to fold it again so the feature is on the folded part
I cannot project flat pattern or use cut across bend - Because it is a spline, according to inventor.
Best regards
Yannick NIelsen
Solved by -niels-. Go to Solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Oh. I didn't think of that! - Yes, that worked perfectly fine 🙂
