Inventor Forum
flat pattern 2d translator not installed and save copy as dxf problem
3 REPLIES 3
kralsadov
502 Views, 3 Replies
Hi friend,
   I am working with inventor 2014 professional now. But There is a problem
it is ( a: 2d translator not installed  and  b:sketch export failed ) .
  dxf drawings of sheet metal environment, particularly these problems started recording format.1.JPG2.JPG
3 REPLIES 3
JDMather
in reply to: kralsadov
Have you installed Update 2 (you didn't say)?
Did you reboot the computer and the problem persists?
Did you create new files from scratch and the problem persists?
Did it used to work fine?
kralsadov
in reply to: JDMather
yes my friend I wrote all of the stages performed the.
I repaired the program. but did not change any.
autodesk 2014 version is not the solution to any of the pages.
Thank you for your interest.
If you have any suggestions other than write.
w.pepping
Sometimes I have the same issue. If I try to export to a Dropbox folder I get the same error. If I change the location to for example my documents the export works fine.
Sometimes when I change the export format to dxf 2000 instead of R12 the export goes on. This on my windows 8 laptop. On my windows 7 desktop I never had this error.
Are there more people with this problem and is there someone who knows what it could be?
Get control of your sheet metal files.
Download the app from matprop.com
