Inventor Forum
Flat Patter Problem
3 REPLIES 3
SMPConsulting
370 Views, 3 Replies
Flat Patter Problem
Hi Folks,
I've created a part that is one half of a round-to-slot transition for use in a piping system. I have created the part by lofting as a surface and then creating a thickness of 6mm.
The problem I am having is with trying to create a flat pattern. It seems to work with errors but the part is not completely flat.
I have attached the ipt file and also some screen snipes showing the folded part and the flat pattern.
Does anyone know why this might be? Any help/advice would be gratefully appreciated.
Cheers
Mr SMP.
Anthony Paul
www.smpconsulting.com.au
An Inventor user since IV6 2002, and a 3D AutoCad user since R9 1989
i7 7770 @ 3.6GHz – 4.2, GB H110M M.2 Mainboard, 2 x 8 GB DDR4 RAM
250 GB SSD 960 Evo Series SSD, 700 W 80+ ATX Power Supply, Win 10 Home 64 Bit
3 REPLIES 3
pcrawley
in reply to: SMPConsulting
Yes - the problem is that this is a Lofted surface that has been thickened.  They fail 99.9% of the time.
For a shape like this, delete your Loft & thicken features keeping the 2 sketches, then create a sheet metal "Lofted Flange between them.  Done.
Peter
SMPConsulting
in reply to: pcrawley
Thanx heaps Peter, just tried it and it worked a gem. I owe you big time!
Anthony Paul
pcrawley
No problem.  Glad it worked.
If you wanted to do something in return, go and add kudos to a few of the Ideas on the Idea Station.
(Specifically this one!  One of my personal favourites.)
Peter
