ebjco
Generally you will want to send the IPT along with the IDW.
Generally in Sheetmetal work dimension go to the theoretical intersection. The
theoretical intersection on your part is still 2"
You can prove this by dimensioning to it. see how here
http://www.mymcad.com/KWiK/iClips/iClips.htm
What it sounds like you are now wanting is the outside tangents of the bends to be 2"?
You would have to calculate it or do it by trial and error, by making the original face
longer than 2".
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Kent Keller" wrote in message
news:29298A22617D6FA7958F54EB63368DBD@in.WebX.maYIadrTaRb...
> To zip up a part you need something like winzip www.winzip.com
> to post it to Inventor.customer files. follow the appropriate link here
> Web
> http://discussion.autodesk.com/WebX?14@186.Fx3taaT3ofu.79@.f15ad3a
> Newsreader
> news://discussion.autodesk.com/autodesk.inventor.customer-files
> if on the web side start a new topic and use the browse tool to pick the zip file. If
> using a newsreader use the attach function.
> Kent
> Assistant Moderator
