Does anyone know why Autodesk doesn't put Flanged Ball Valves in the content center? There are several other types of valves in there but no flanged valves. This type of valve is very common in the oil and gas industry and it just baffles me that there is nothing there for this type of valve. I have used Inventor for several years and this has always been an issue. If someone has found a work around I would love to hear it. Thanks in advance for any help.
I believe that it is simply because there are so many variations, and many of these are specific to the manufacturer of the valve. It would be nearly impossible to capture them all. All of the many valves we use in our application (chemical processing) were modeled here, authored and then published to the CC. they may not be pretty, but the envelope dimensions are correct and they have a reasonable resemblance to the original.
You could also take a look at sites on the internest duch as Grabcad, where you may be able to find at least some of the valves you're looking for.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
If a part you need isn't in the content center, you can create it yourself. Check out this link (click here) for some instructions to get started.
Also, you will want to read up on iParts if you aren't familiar with them.
Good luck!
Cameron Whetten
Inventor 2014
Some manufacturers also make models available on their websites, for example Asahi America has a full library available for download,.... one model at a time, but they are nice models.
Chris Benner
I have created and added quite a few Asahi valves to my content center, including flanged pvc ball valves. I also have some Spears valves. All were created using dimensions from the manufacturer's catalogs, and in the case of the Asahi valves, from their downloadable models.
I am willing to share the iParts with you. If you would like them, give me your email address by sending me a personal message on the forum.
Cameron Whetten
Inventor 2014
