Inventor Forum
Flange sheet metal part from inner edges
1 REPLY 1
ccsmith25
562 Views, 1 Reply
I would like to ask any support to how can I solve the problem I have to face.
I have a metal sheet part. In the middle of it there is a square shape cutting.
I would like to create a flange to get the final flat pattern as you can see in the attached file nemed "flat pattern.png".
1 REPLY 1
mpatchus
in reply to: ccsmith25
Adjust your corner setting for the flange.
Apply a CORNER CHAMFER to the edges of the flanges.
Your flat pattern should look like this.  You may have to tweak your flange corner settings (or GAP settings) to achieve the desired final part.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
