If I had a sheet metal part with one flange, can I animate the flange from 0 to 90 degrees??
I threw it into an assebmly but the thing is you need two parts to do so but I have only 1 part to work with.
Short of iLogic, you might already have the best method.
Are you talking about say in a simulation program?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
What is the purpose?
You might create a part with an arc length set and a radius parameter.
In Inventor Studio - Animate Parameter from very large radius (approaching straight line curve) to finished radius.
