Kent,
You can create a document "on the fly" by holding down CTRL+SHIFT then
create a new document using the pull down pull-down (as opposed to the File
Open dialog).
TAHDESIGN,
Would you consider posting your part template to the
autodesk.customer.files forum so we may take a look? If Kent's
suggestion(s) don't work for some reason, we can post new templates for you.
Just let us know which release version you would like. Also, did you
customize your templates in any way?
Best regards,
Hugh Henderson (Inventor Workflow QA)
"Kent Keller" wrote in message
news:41dc0211$1_3@newsprd01...
> You could try opening the template and changing the sketch name to
> sketch1 but I am guessing the next sketch made would be sketch4.
> If I remember right there is a way to start a new file that isn't based
> off a template?? Unfortunately I don't remember how, but maybe someone
> else does? If I am not just dreaming about it you could do that,
> then set things the way you want them, and finally save over the top of
> the standard.ipt.
> Kent Keller
> http://www.KWiKMcad.com
> Autodesk Discussion Group Facilitator
> "TAHDESIGN" wrote in message
> news:22549914.1104929546935.JavaMail.jive@jiveforum1.autodesk.com...
> >I recently made a slight change to my part template file. I turn on the
> >origin planes from the RMB menu. This way the toggling of the plane
> >visibility is available in my newly made parts.
> > However, now the first sketch in all my new parts is sketch3.
> > Any ideas as to why and any way to get it back so that my first sketch
> > is sketch1?
