I keep getting this "You must first resolve files before checking in" error. And I get that, I re-arranged some very badly organized legacy libraries, and probably 1/100 files took issue with this, and I have been working through resolving the links as I go. Some turbulence was expected.
Now I've hit a wall, I keep getting these errors, but no dialog, or question mark, or any way to resolve some of the links are apparent.
See picture, the breather cap it wants is right there, shows no issues, I've replaced the part from it's new home and it looks fine, but gives me that heinous error when I try to check it in.
Any ideas?
Try opening Hyd Tank Vented Cap.iam on its own and checking it it.
You might get a more specific message or a better clue regarding the underlying problem.
(You mentioned reorganising libraries - did you map them correctly in the Vault mapping?)
It opens with no apparent issues, doesn't even ask to update.
Since I don't know what vault mapping is, I'd guess not.
I used vault to move everything, so I would hope that it did what it needed to.
