Inventor Forum
Finished Belt tightener
16 REPLIES 16
Message 1 of 17
obermesik
3765 Views, 16 Replies
Finally finished my latesest project. Let me know what everyone thinks !
Nick Obermesik
16 REPLIES 16
Message 2 of 17
blair
in reply to: obermesik
Look good, then you just need to take it to the next level.
Delta Tau Chi ΔΤΧ
Message 3 of 17
JDMather
I (or my students) have modeled this assembly thousands of times.
Attach the assembly here and I will give you an assessment of the modeling techniques that you used.   (very few do it correctly)
The CADWhisperer YouTube Channel
Message 4 of 17
mpatchus
in reply to: JDMather
This one was always one of my favorite projects for my students.
Looks deceptively simple at first glance, but you are correct JD, very few ever modeled it correctly.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 5 of 17
chad38
Very nice looking drawing dude. Take the advice of these guys for these days, the way you model things can come back to bite you. If you want to become powerful you need to know the most efficient and the most reliable ways to do these things because when something changes in a design, if your assembly falls apart you are back to square one.
HP Z420 Workstation
Intel Xeon CPU E5-1603 0 @ 2.80 GHz 2.80 GHz
12.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Solid Edge ST9 MP1
Inventor Professional 2015
Autocad 2015
SolidWorks 2015
Message 6 of 17
Mario428
WOW tough crowd!!! Thought it looked quite good myself.
Definition of " modeled correctly!!!! " would be interested in that myself.
Normal definition would be if the end product matches the requirements.
Following an exact set of steps to get to the final product, little **** maybe?????
Message 7 of 17
obermesik
Hey this is my project file. Please give me your feedback anything that will help me to fully expand my feaild of knowledge with Autodesk Inventor
Nick Obermesik
Message 8 of 17
obermesik
field *
Nick Obermesik
Message 9 of 17
JDMather
I can't tell anything about modeling technique from a 2D drawing.
Attach the Frame.ipt file here.  (and all of the parts if you are really interested in making sure you got it right)
(I must warn you that I am not the type to give trophies just for participation.  But I do give good tip (IMO) and accolades for work well done.)
Message 10 of 17
blair
What JD and other instructors are looking for, is sound modeling techniques. Are all the sketches fully and properly constrained. Did the person take advantage of the Origin work planes and make use of symmetry in the construction. Did the person take 5 steps to accomplish something that could have been done in 2 steps.
Delta Tau Chi ΔΤΧ
Message 11 of 17
obermesik
I believe this is what you are looking for sorry.
Nick Obermesik
Message 12 of 17
GSE_Dan_A
You must also attach the part files that are associated with the Assembly and Presentation file....
GSE Consultants Inc.
Windsor, ON. Canada
Message 13 of 17
obermesik
in reply to: GSE_Dan_A
when i try to do that it only lets me attach 3 files per message do you want me to send multiple messages?
Nick Obermesik
Message 14 of 17
GSE_Dan_A
A good tip is to open each part and move the End of Part Marker all the way up.  This cuts down on file size.  To answer your question, yes you can post all the parts in as many messages as it takes.
Windsor, ON. Canada
Message 15 of 17
JDMather
You can place all files into a single folder.
Right click on the folder name and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
Now you have already learned several things that you did not already know -
1. An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
2. Find the red End of Part marker in the browser.
(End of Folded on sheet metal parts EOF)
Drag the red EOP to the top of the browser hiding all features.
Save the file with the EOP in a rolled up state.
Right click on the file name and select Send to Compressed (zipped) Folder.
Message 16 of 17
obermesik
I tried doing a compressed file but it wouldn't let me send it because the byte size was to big
Nick Obermesik
Message 17 of 17
JDMather
Then one part (*.ipt) at a time following these instructions -
