Inventor Forum
Finding reference parameter in ipt
4 REPLIES 4
3DSetout
1237 Views, 4 Replies
Hi Inventor Technicians
Is there a way to identify what sketch or Solid a reference parameter (d0, d1, d2 etc) is in / on.
MatB
4 REPLIES 4
cwhetten
in reply to: 3DSetout
Hi.
My first inclination was to say that you just hover your mouse over the name of the parameter and it will show you the parent, just like it does with model and user parameters.
But, I decided to test it--and it doesn't work.  Whoever programmed that aspect of the parameters dialog forgot to include that behavior for the reference parameters!  Not cool!
So, I don't see a way to find where a reference parameter is defined, other than hunting through the entire part.  Smiley Sad
Cameron Whetten
Inventor 2014
3DSetout
in reply to: cwhetten
Thanks Cameron
. . I did not know that even that limited functionality,
Of the 'Parameter to sketch' identifier existed. .
it even works on my embedded excel Parameters.
At least now I will be able to find Model parameters easily.
Thats cool. But not as cool as the 'possible but forgotten' call.
Sometimes the list is too long to be displayed for some parameters.
Q- is there another way to view the expanded 'Parameter to sketch' information text. .
Thanks MatB
cwhetten
Hmm...  Not that I know of, unfortunately.  At least, not without some customized programming.
Cameron Whetten
Inventor 2014
j.glim
Hi MatB,
Stumbled upon the same issue.
Wrote this:
Public Sub FindRefParamParent()
Dim oParam As Parameters
Set oParam = ThisApplication.ActiveDocument.ComponentDefinition.Parameters
Dim oRP As ReferenceParameter
Dim oSkt As Sketch
Dim SktParam As DimensionConstraint
ThisApplication.ScreenUpdating = False
For Each oRP In oParam.ReferenceParameters  'Call Reference Parameter
    For Each oSkt In oRP.Parent.ComponentDefinition.Sketches 'Call parent of referenced parameter
        For Each SktParam In oSkt.DimensionConstraints
            If SktParam.Parameter.Name = oRP.Name Then
                MsgBox "Parameter Name " & oRP.Name & " is Consumed By " & oSkt.Name
        Next
    Next
Next
ThisApplication.ScreenUpdating = True
End Sub
Worked for me!
