we are currently using the simple T=fxd method to find if things tip over, but, we are exporting the files into AutoCAD to do it. I would like to keep everything in Inventor and just do it as a simulation.
Why even bother with Simulation. If the angle produced between the CG and perpendicular and the CG to the supporting edge/legs is less than the tip angle it will fall over for a static unit.
Once the CG moves outside of the support/base it will tip over.
Simply model the TV with the correct mass and size/CG location and place it on the stand in a assembly.
