Inventor Forum
find all assemblies in which component X is placed
6 REPLIES 6
526 Views, 6 Replies
Within a top level assembly, is there a way to find all assemblies in which component X (either part or assembly) is placed? I ask because I need to resolve duplicate filenames (877 of them to be exact) before Vaulting a project.
6 REPLIES 6
Cadmanto
I think Design Assistant has where used capabilities.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
swalton
Design Assistant can do what you want, but it might be slow.  Look at the Tools-Find-Where Used menu pick.
You might be better off creating a new, temperary Vault on your ADMS server just for this project.  Turn off unique filenames for this Vault and load your project into it.  Use the Where-used tool in vault and the replace component command in IV to clean up the files.  You can also re-work the folder structure if needed.
Once it is all clean, download a fresh copy to your temp workspace and use Windows Explorer to put it where the production Vault can see it.  Then load it into the production Vault as normal.
Steve Walton
Inventor 2023
Vault Professional 2023
blair
in reply to: Cadmanto
Yes, DA has this feature, there also is a Find-Where-Used function in Vault as well.
Delta Tau Chi ΔΤΧ
Would you please give feedback to this post? It explains a bit more in detail. Thanks! http://forums.autodesk.com/t5/Vault-General/Resolving-duplicate-filenames/td-p/4773315
Autoloader gave me the report of duplicate filenames and their location. What that report lacks is what assemblies these components reside in. I can obtain a Hierarchy Report from Design Assistant. So, between the Hierarchy Report and Autoloader Duplicate Filename Report, it will just be a matter of opening each assembly inside of Design Assistant and making the problem filenames unique. (o.O) Oh joy.
Thanks all who offered suggestions.
raith-mb
You can use the tool Clever from CoolOrange - yust Google this Name. You can download a 30 day Test Version here: http://www.coolorange.com/en/products/clever Clever will create a data base of all your Inventor files. It takes about 1 hour to index 10.000 files. After indexing you can open ech duplicate part aftr each other an Show "Parents". Then you candirectly open the IAM by clicking the thumbnail. I use it, but it actual has some Trouble recognising the replace of a part. That means the part will be shown still in the IAM for a few Minutes after replace. But anyway it is a cool tool. Much Fun 🙂 Roland
