Is it straight edges and constant radius fillets? If so could you just
extrude cut the fillets?
If you have to go the derived route, you could place a view of the
assembly off the sheet and use it for the bom/partslist. Ballooning
might be a issue though 8^/
Kent Keller
http://www.KWiKMcad.com (Please update your links)
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"ARCross" wrote in message
news:29664525.1075588555337.JavaMail.jive@jiveforum2.autodesk.com...
> I have an assembly that recquires post-assembly machining. I could
derive it but then, is there a way to get the parts in the original
assembly to show up in the parts list? I haven't seen a way to do
this.
> If I could get the fillet command in the assembly enviroment then I
would be set to go but I only see chamfer, extrude, hole, etc.
> Any bright ideas?
