I can't fillet this...I'm trying to get a gradually incrasing fillet form the nose to around a third from the front, then constant all the way back, but Ii can't really get it to do anything.
Solved by alewer. Go to Solution.
See attached. Fillet 17 does the job, but it doesn't work unless you create Fillet17 to prepare the edge.
Good luck with your CO2 dragster.
@Anonymous wrote:
I'm just learning Inventor on a project-by-project basis.
Michal J. Turkiewicz
I can help you with a better technique if interested.
