Inventor Forum
Fillet
11 REPLIES 11
Message 1 of 12
367 Views, 11 Replies
Fillet
How can you do the bottom raduis? Overall part in 2" X 2.25"X 1" raduis is .5
11 REPLIES 11
Message 2 of 12
VdVeek
If you can attach your ipt it's a lot easier for us to help.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
Message 3 of 12
in reply to: VdVeek
Here is the file
Message 4 of 12
JoAnn_Hogan
First of all, Your sketch should ALWAYS be fully constrained. It is not constraied at all.
Secondly, You have lines over each other, and very small gaps (Which would have been prevented if your sketch was constrained.
Third, It wouldnt do the fillet with that radius with all these gaps.
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Message 5 of 12
JDMather
I found the part fairly easy to model in Inventor.
But there are several things I couldn't figure out -
1. Why didn't you use the Origin Center Point for symmetry?
2. How did you create perfect sketch arcs without dimensions (did you erase the dimensions for some reason)?
3. As already noted, why do you have lines overtop of lines?
Your original screen capture looks like it might be from SolidWorks.  Is that the case?  If so, can you zip and attach the original file here?
Message 6 of 12
in reply to: JDMather
1. Why didn't you use the Origin Center Point for symmetry? I dont know, just start drawing. I am new to this
2. How did you create perfect sketch arcs without dimensions (did you erase the dimensions for some reason)? Yes, I erase them.
3. As already noted, why do you have lines overtop of lines? Did not know I had lines overtop of lines. How did you know that? Can you send me the part you made?
Message 7 of 12
in reply to: JoAnn_Hogan
How you know I have very small gaps? I am new to this.
Message 8 of 12
JDMather
Where are you getting the information for creating the geometry?  Do you have another file? A drawing?  Can you attach this information here?
I recommend you start here
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
Message 9 of 12
JDMather
@Anonymous wrote:
 raduis is .5
 In the image all radii appear to be identical.
In your sketch 1 all radii are .25
In your sketch 2 you have radii .5 - where did this information come from when all radii in the original are the same?
Message 10 of 12
No orignal drawing just a sample. somebody else did the 2 sketch 2 with .5 radii.  How did you draw the part?
Message 11 of 12
JDMather
Sample what?  File?  Picture?   Where are you getting the dimensions - they have to come from a source?
Message 12 of 12
JoAnn_Hogan
Please have a look at the attachment. It is not completely the same as your model but it is a idea on how you would model it.
  • So first of all your sketch should ALWAYS be fully constrained.
  • Secondly you had lines and gaps. If your sketh was fully constrained that would not happen
  • Because you had gaps the fillet wont work (It couldnt fillet the gaps)
  • As soon as you got your constraints correct you will be able to fillet.
In the "TEST" part I tried to get the part as close to yours as possible. Please have a look
Jo - Ann
