Inventor General Discussion
Valued Contributor
2 Kudos
Post 1 of 3
Fillet "how to" question
172 Views, 2 Replies
10-11-2012 06:45 AM
Hello.  I remember seeing a solution to a similar problem in the past posted by JD Mather however I cannot seem to locate it now.  I need to apply a fillet along the highlighted edge in the image.  Even using a variable fillet with "0" radius at the start and stop fails.  Any ideas?
Thanks;
Nick
2,121 Kudos
Post 2 of 3
Re: Fillet "how to" question
10-11-2012 06:51 AM in reply to: nickseman
Edge fillet doesn't work?
Face fillet doesn't work?
Attach the file here.
Maybe this is what you were thinking about
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%204.pdf
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
2 Kudos
Post 3 of 3
10-11-2012 06:59 AM in reply to: JDMather
Mr. Mather:
Yes - that was the tutorial I had seen previously.  Thanks for your help.
Nick
