Inventor Forum
fillet problem
12 REPLIES 12
Message 1 of 13
billco-mfg
582 Views, 12 Replies
fillet problem
Take a look at the attached picture.
I understand why the fillet is doing this, but I'm not sure how to get around it easily.
12 REPLIES 12
Message 2 of 13
in reply to: billco-mfg
What are your options set to?
Did you try increasing the value of the radius? Thanks.
Message 3 of 13
billco-mfg
That only makes it more obvious. The fillet won't extend beyond the length of the original edge.
Message 4 of 13
Create the part as a Surface(s) then Thicken.
QBZ
wrote in message news:5090880@discussion.autodesk.com...
Message 5 of 13
billco-mfg
That's what I did, but I'm not sure how to get the fillet in the surfaces.
Message 6 of 13
Here is a messy example of using a sketch to split the surface to get the
corners.
Attn: Shekar... Unsuppress the last fillet in this part.... you may want to
file this under the "parts that show extra geometry" folder.
QBZ
wrote in message news:5090907@discussion.autodesk.com...
Message 7 of 13
billco-mfg
I never would have come up with that.
Unfortunately, I went about creating the part differently that you did (there's more to the model than the picture showed). Using the method that you posted would not be 'simple'. It is just a model of a coupling anyway. I can stand to leave the fillet out.
I would hope that Autodesk would look into fixing the problem. You don't get the same result if the bounding surfaces are flat.
Message 8 of 13
Yes I see a disc as in attached image. Logged issue: 761747. Thanks.
shekar
Message 9 of 13
billco-mfg
That's a different issue than the picture that I posted.
Message 10 of 13
It is an ongoing issue with ShapeMangler.
If you ever get this kind of junk post/send it to Shekar so they can try to
figure it out.
Predominately it is seen with Revolve Features.
QBZ
wrote in message news:5091020@discussion.autodesk.com...
Message 11 of 13
billco-mfg
here is the file
Message 12 of 13
No problem.
You can loft edges of surface to form a corner.
The "bottom" surface could probably be split again so that the corners would
be automatically included but quick'n'dirty seems to be the theme of the day
hence the multiple Thicken Features.
Nice Exercise.
QBZ
wrote in message news:5091071@discussion.autodesk.com...
here is the file
Message 13 of 13
billco-mfg
Looks good... but your solution still causes problems down the road (see attached).
